compression Question ?
Whats the est. compression on the pistons combo on ur setup? I would def get rid of the cometic gasket and go for a oem Honda gasket and it'll work up to 82mm with no problems. If you have 89mm stroke your compression caclulator is gonna be higher like for a ls/vtec setup w b18c1 head.
ya i know i wish i woulda had a gsr head but my head is already done & assembled, but ill prolly get a thinner head gasket since a 81mm will work for my 82mm bore.
chris- im pretty sure ima run skunk2 pro2's or 3's. either or not sure yet.
My setup -
82mm gsr w/pr3's & ls crank
B16 head 3 angle valve job,mild p&p,over sized flat top valves. fully built.
Skunk2 pro2's or 3's.
^nice get it nicely tuned and should be able to hit 200hp and just take care of it lol
i love AUTOZONE
i love AUTOZONE
Weve never had a problem with cometic headgaskets
Most people go by what they heard...they r good.i myself stick with felpro.
i love AUTOZONE
i love AUTOZONE
thanks dave...Well shit im just gonna keep the gasket i have then cause its already sitting in my room lol.
When i use that zealAutowerks compression calculator it says my gasket 0.8mm will actully make it a tad higher than a oem 0.026 inches
Use oem or cometic head gaskets. If you using quality parts in your build,use quality gaskets.
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
727-510-6301
agreed.
PM me for any AC, audio, and wiring work on your vehicle. Including but not limited to car audio, alarms, gauge installs, custom clusters, full troubleshooting, big/dual fuel pump relay kits, battery relocation, factory radio iPod and amplifier integration, custom harnesses, and custom standalone ecu installs and much more! If you need it done, we can do it! Don't be afraid to inquire!
changing cams will not change the compression ratio. you may get higher cylinder pressures due to cams having different overlaps but it will not increase your physical compression ratio, there is a difference. the only way to increase compression ratio is to decrease combustion chamber volume. putting bigger cams in a motor that doesn't have a high enough compression ratio is the exact opposite of what you need to do.
