Timing belt tensioner
Old Aug 12, 2002 | 05:12 PM
99B16Si's Avatar
if its never been off before its probably pretty tight, try using a normal wrench with a 14mm because most big wrenches wont fit down there, and put some kind of bar over it to give u more torque. try from the top, if that fails try from the bottom. i think its easier from the top tho. goodluck
Old Aug 12, 2002 | 05:49 PM
Joker's Avatar
Eat My Ass With a Spoon
air tools, they work wonders. loosen the drivers side mount so you can get in there have some room to work.
Old Aug 12, 2002 | 10:32 PM
99B16Si's Avatar
goodluck getting an impact in there...theres barely enough room for a small ratchet
Old Aug 13, 2002 | 03:54 PM
letsrollagn's Avatar
BRT OVERKILL
Remove the drivers mounts and the one bolt in the rear mount and jack the motor up a few inches and you got plenty of room.....
Old Aug 13, 2002 | 08:04 PM
99B16Si's Avatar
thats too much work, just get a damn bar to put over it
Old Aug 14, 2002 | 07:14 AM
2qk4u's Avatar
make sure u use a 6 pt socket, using a 12 will strip it out.
i did that shit to mine and had to order a new one from acura
