b18c in 00 hatchback
Old Aug 8, 2002 | 11:07 AM
chet's Avatar
All Aboard
Default b18c in 00 hatchback
alright, here is what i'm helping this kid do.
he has a jdm b18c from a 94 integra gsr. the car he's putting this engine in is a 2000 civic dx hatchback. now, my question is which driver's side bracket is used with the b18c motor mount.
does he use the dx mount and bracket? we haven't measured yet but it looks like the dx mount will not fit onto the b18c motor mount bolts.
does he need to buy a civic si bracket that will be compatible with the b18c mount?
i've never done this swap but i've read several accounts of this swap and not once has anyone described this problem.
Old Aug 8, 2002 | 02:39 PM
SPEED123's Avatar
you need the civic si driver bracket a/c bracket and i believe the tranny bracket but don't qoute me on the tranny.
Old Aug 8, 2002 | 07:00 PM
99B16Si's Avatar
yea he needs a civic si driver upper motor mount bracket and the rear tranny mount off of a 99-00 civic si. im not too sure that the lower driver mount will fit either
Old Aug 8, 2002 | 10:23 PM
vshivik's Avatar
what is the civic si driver bracket? is it the part that mounts with two bolts to the engine head and has to threaded rods stickin out of it for the metal bracket to go on? or is it something else, or do i need that with something that metal bracket? btw, how many bolts go into the head from this mount braket thing?? if two, are they one on top of another or one underneath another?? BTW, i'm the guy that chet is helping with, with the swap. thanks to all.
Old Aug 9, 2002 | 08:24 AM
99B16Si's Avatar
none of the bolts go into the head, they all go into the block. and yes the bracket is the part that connects the two parts of the mount from the block to the actual liquid filled mount. i was assuming your motor came with the part that bolts to the block...that would definitely help. you also need the rear tranny civic si mounting bracket that bolts to both the block and tranny. and for some reason i think the gsr lower driver mount is slightly different.
Old Aug 9, 2002 | 08:49 AM
vshivik's Avatar
cool. the dx did come with that piece that bolts into the bock, however, it's different and won't bolt into the b18c block. the b18c block has two holes for bolts, the d series block only has one. so, i'm assuming that the si braket also has two bolts, since it comes from a B series block. i hope they didn't change that for the last gen si (99.00). still skeptical about ordering it, want to make sure that it will definately fit into the b18c. so, basically the question remains as follows: will a 99, 00 civic si driver side mount braket fit into the b18c block?? thanks, i appreciate your patience and adivece.
Old Aug 9, 2002 | 09:24 AM
99B16Si's Avatar
the part of the mount that bolts to the block is interchangeable in all b-series blocks(it has two long pointed threads sticking up). the actualy liquid filled mount part is different from a gsr to a civic so you will need the bracket off off a 99-00 civic si to connect that part that bolts from the block to your mount on your civic. hope that helps
Old Aug 11, 2002 | 09:24 AM
vshivik's Avatar
thanks. i will have to get that piece. what about the bracket that goes onto that and the mount on the car? can i reuse the dx bracket, it looks the same, not that i have the si one, but from pics and stuff, seems to be identical. you think that even if they're same in shape the si might be stronger??? thanks.
Old Aug 12, 2002 | 07:05 AM
letsrollagn's Avatar
BRT OVERKILL
also there is the issue of the knock sensor, crank speed fluctuation sensor etc if you are using a 99-00 ecu, does he have a OBD2-1 conversion harness?
