lot of smoke from valve cover nipple
hello. So i just recently built a ls v with ctr pistons and b16 head with itr cams. Now i used to have the hose from nipple iinto my intake and i realized i had oil dripping from my intake. I pulled the hose ff and it had oil dripping from it. I pulled off the hose and this is what i have now..... Heres a vid. notice all the smoke.
can anyone help me please. motor only has about 2k miles on it. I have a catch can and a pcv valve but its blowing so much that oil even with catch can still gets into my intake... (hose from nipple to catch and other end to intake. they are also on the right nipples on the catch can.)
Definetly a possibility of a bad build. Your getting hella blow by pistons or rings might be fucked. My car smoked out the breather after I blew my pistons I didnt know so I kept running it. It soon started smoking out the tail pipe like crazy. Pull the head asap.
"Proven Power. Nuff Said"
"God is Good"
um. car does smoke in higher rpms also. block was hot tanked and all. so u think my rings may be fucked? how? At one point my timimg was off and it had double ignition/ spark. It caused a nasty spark knock but i only drove it like that and didnt push it for the first like 400 miles. every since then the blow by has been getting worse...
^yup, bad rings, shitty or no machine work to the block, or both lol
PM me for any AC, audio, and wiring work on your vehicle. Including but not limited to car audio, alarms, gauge installs, custom clusters, full troubleshooting, big/dual fuel pump relay kits, battery relocation, factory radio iPod and amplifier integration, custom harnesses, and custom standalone ecu installs and much more! If you need it done, we can do it! Don't be afraid to inquire!
If you or anyone HEARS what they THINK is detonation while driving normally. Don't drive the car again. You should never hear detonation inside a car without knock phones. In the years I have been tuning. I think I have heard actual detonation two, maybe three times. Being your physyical timing was that far out and your ignition timing was that far out I am sure you experienced quite a bit of pre ignition as well. Compression test and leakdown test the engine. You should have done that before making this post. If you didn't know that. Now you know. But. Most likely going to need new pistons and rings at minimum. Possibly hone, valves, bearings, etc.
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
* IP E-Mail
* IP Face Book
* IP Web-Site
^true story...
i could not tell you how many pistons i see like this a month when i take apart a Ctr pistoned lsvtec lol...or just someone thinking they can run 18osi on stock pistons everyday...its just sad
i love AUTOZONE
i love AUTOZONE
