water pump replacement ?s
Old Sep 1, 2010 | 04:17 PM
Pennywise's Avatar
why so serious????
Default water pump replacement ?s
i got a 92 Honda Accord with a F22A1. the water pump is leaking water out of it...well i assume its the water pump, because everytime i stop there is a large puddle right under the front driver side tire, right above that is the water pump. i have a new one to put on, but i just wanna know if its a hard job or something i can do in a day, i am pretty good with cars and fixing them, im just kinda new to the honda world, any help would be appreciated
thanks steven
Cornbread Crew member #754
Old Sep 1, 2010 | 04:30 PM
flatrex's Avatar
crx hatch sedan
Can you change your timing belt? If so you can do the water pump. If your not comfortable doing it shared_pm me
Old Sep 1, 2010 | 05:34 PM
civic99's Avatar
No real JDM here
thats where my a/c hose is so maybe its urs a/c ?
Tamparacing.com, the perfect place to find desperate single men in their 20s and 30s.
Old Sep 2, 2010 | 08:55 AM
Pennywise's Avatar
why so serious????
theres def no a/c in the car..it used to be turbo so its pretty bare bones under the hood...it leaks pretty bad i can fill up the radaitor and within maybe 5 - 10 miles down the road it will start to over heat from all the water leakin out
Old Sep 2, 2010 | 10:51 AM
NeKe1point0's Avatar
I would reccomned changing balance shaft belt, timing belt, water pump, o ring on water neck, tensioner and SPRING ! (ALWAYS overlooked and EXTREMELY important to replace).
PM me for pricing
Proven Power LLC
4505 N. 56th street
Tampa, FL 33610
813-988-DYNO(3966)
www.ProvenPowerTampa.com
Old Sep 2, 2010 | 12:36 PM
Pennywise's Avatar
why so serious????
so turns out its harder than i thought....anyone know a good mechanic?
Old Sep 2, 2010 | 02:35 PM
HondaHouse's Avatar
IS AT THE DEALERSHIP NOW
if you weren't so far away......dealer tech here......its really not that hard of a job, just if you've never done a t-belt....yeah, f22 with balance shaft belt isn't really that motor to learn on.....
Mike @ 239-851-3234...anything pertaining to HONDAS
Originally Posted by Jordan T
sounds like you have a problem, your car is a mitsubishi, try replacing it.
Old Sep 2, 2010 | 02:37 PM
HondaHouse's Avatar
PM me for pricing
don't forget your seals also.....and the balance shaft gear oil seal(its like an oval design oring seal.....soooo overlooked, and always bites in the ass with oil leaks
Old Sep 3, 2010 | 03:27 PM
Pennywise's Avatar
why so serious????
dealer tech huh? so you do work on the side, i wanna get some who knows what there doin change it out for me...i will replace all the parts you are takin about, do you kno bout how much for parts and labor to put them in?
Old Sep 3, 2010 | 03:47 PM
HondaHouse's Avatar
yes, i work for the dealer.......i can get prices for you.....oem and aftermarket......but now remember.......im in fort myers.......2 hrs south of tampa
