Integra Brakes on a civic del sol
Will 97 Integra GSR brakes fit on a Del Sol? What items from the integra do I need to swap the brakes on? Calipers, hubs, rotors, brakes, brake booster, master cylinder? Anything else?
yes, they will, if your wheels are big enough...ie, no 13 inch steelies if you're running around with a del sol s. you'll need everything you listed...and also you may need the ebrake cable.
the whole switch will be easier if you have the entire rear control arms so you can keep the rear discs together...i'm taking everything apart to save a few hundred dollars and its a bitch.
