ok me and my friend were arguing about wether a cabble clutch disk can work on hydro
Old Aug 29, 2010 | 12:59 PM
surfrevo's Avatar
Default ok me and my friend were arguing about wether a cabble clutch disk can work on hydro
thanks for any info... Gage
Old Aug 29, 2010 | 02:33 PM
surfrevo's Avatar
no one can give me an answer??
Old Aug 29, 2010 | 02:45 PM
poorboy44's Avatar
TR Balla Donor Supreme
assuming that you're talking about b series, the only cable clutch that will with a hydro trans is the b17a1 gsr.... any other cable clutch set will not work in with a hydro transmission.....
http://www.inductionperformance.com/
R.I.P
Kevin "Slo_Si" Gonzalez
6/21/86-9/13/06
Pablo Garcia
9/28/85-9/05/07
You will be missed and remembered forever!!!!
Old Aug 29, 2010 | 04:07 PM
surfrevo's Avatar
ok yeah i have a yz1 and i just bought an act 4 puc a while ago dont really want to have to buy another one. is how the debate started.
next question is one better than another cable or hydro? and yes b-series
Old Aug 29, 2010 | 06:01 PM
hondachris1994's Avatar
hatchback1994
I put a hydro clutch in a cable tranny(d-series) a cpl years back but I ended up breaking the clutch pedal cause the pedal was sooo stiff. It was a ACT clutch and I was told it was a cable clutch but in the end I found out it wasnt the hard way, had to pull tranny to put the correct clutch in and had to have my clutch pedal welded back in place
Old Aug 29, 2010 | 06:18 PM
flatrex's Avatar
crx hatch sedan
My ys1 will accept both
Old Aug 29, 2010 | 07:37 PM
HondaHouse's Avatar
IS AT THE DEALERSHIP NOW
92 and up b series clutches are the same....size and spline count........all interchangable..........and been doin it for years.
and fyi:92 and 93 b series trannys only......same internals as hydro trannys
Mike @ 239-851-3234...anything pertaining to HONDAS
Originally Posted by Jordan T
sounds like you have a problem, your car is a mitsubishi, try replacing it.
