speed meter and rshared_pm not working? helpppp pleaseeeeeeeee
the lights and works and emergence break light works but the speed meter aint working. the rshared_pm was bounce like crazy and now speed meter wont work or the rpm, i think is the vss? can yall help please thanks, and if yall think it is the vss where is it located?
Chirby, you need to start posting your stuff in Honda/Acura Tech man. Youll get more specific advice in there.
bring it to our shop we take a look at it
JAY TUNING! YOUR tuning solutions
ECU Chipping and Reflash, Dyno Tuning,
CUSTOM MAPS
FROM OBD0 TO OBD1
ECU repairs
CLICK HERE >>> OUR FACEBOOK SITE
81360091974
CUSTOM MAPS
FROM OBD0 TO OBD1
ECU repairs
81360091974
Is the CEL ON?
First check whether either fuse 24 (15A) (w/ SRS) or 12 (15A) (w/o SRS) is blown. Assuming the VSS is fine (usually the VSS is bad in this situation), next check whether there is an open in the YEL/BLU wire powering the speedo. If all of the latter are fine, then you likely need to replace these gauges.
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
JoKie TuNinG
StricKlyMT
727-510-6301
