Car won't start...
Old Aug 12, 2002 | 11:17 PM
snuffy's Avatar
Default prelude won't start
at first i thought it sounded like a timing problem,but after you said your 1&3 plugs were fouled out with oil,it sounds like a head or headgasket,check the oil for to see if it's thinner than should be,on rare occasions it won't show there you may want to drain the radiator and rub your fingers together under the water to check for any oil in the water :monkspank:
how come they only call when i've got crack???
