Weird ass engine problem......
Guest
Posts: n/a
I finally finished building my motor and put it in this weekend. It runs awesome except for one wierd problem. If I start it cold, it will idle and jump between 1700 and 2000 rpm's until the fan comes on and the motor is warmed up. Then, it idles fine just below 1000 rpm's..... But, when i rev the motor up, it still wants to jump around consistantly between 1700 and 2000 rpm's until i step on the pedal enough to bring it past 2000 rpm's, then it revs up perfectly smooth. It also does this while i'm driving, i'll be going in 1st gear, and once it hits 1700 the car jumps around until i get it past 2000 rpm's....
WTF?? I thought it could be the iacv but why would it do it after the car is warmed up and while i'm driving it?? plus, it still does it when i unplug the iacv.... i also changed computers and it still remains... any opinions on this bizarre problem would be appreciated. thanks,
-Justin
-Justin
I had this problem when I changed my car from automatic to manual it was something wrong with my throttle sensor they needed to adjust it. I dont know if that helps you, by the way my car still does it from time to time.
Guest
Posts: n/a
AH HA! I was thinking the same thing.... but, my JG throttle body came with a brand new tps that was supposed to be "set perfectly" from the factory.... although this tps has room for adjustment back and forth, and it is currently adjusted all the way to one side... i thought that was weird... any other ideas, or anyone know how to properly set a tps?
Guest
Posts: n/a
Originally posted by "RONIN"
throttle body.
throttle body.
Do some troubleshooting guy.
In your own words you said that the TPS seemed "weird" so why not bust out the multimeter (shut up Justin) test the voltage with the throttle plate closed/open and compare to stock voltage readings. That's the first thing I would do when installing a new TB.
sad thing is, that me and you are probably the only 2 people that use this method to solve problems. everyone else depends on messags boards for answers and solutions
Guest
Posts: n/a
well actually, I calibrated the tps a few days ago... it's a perfect .500 volts at closed throttle and it reads a smooth voltage increase to appr. 4.8 at WOT... i've changed the iacv, changed computers and replaced cap and rotor.... right now i'm completely perplexed... any other ideas guys¿¿¿¿... I definately have been doing a whole lot of trouble shooting... just wanted to know if anyone has heard of this problem because it's got me stumped.... i thought it could be the tb, but at closed throttle when the rpm's are coming down after being on the throttle, it tends to stay at 1800-2000 and jump around... although if i hit the gas really quick, it drops fast enough to sometimes get through that spot and idle normally... with the GSR computer the problem isn't as bad, when i accelerate slowly the car jumps at those rpm's, but only sometimes... with the skunk2 program (p2
it does it really bad and wants to always idle/jump around at those rpm's.... so i'm guessing it's electrical, not vac/throttle related... any other suggestions??
