door leak
so waters been leaking into my car, i finally took the door panel off and ran water over my door. water went right between trim and window, so i figured it was the trim/seal. when i called honda and had them look at car, they said the seal only keeps a little bit of the water from coming in. they told me the door membrane (plastic sheet between door frame and panel) was the reason the door was leaking because it had came loose.
Has any1 had this problem, or know if this is actually the problem?
any1's 2cents is appreciated, thanks
I actually just saw this same problem on a BMW last week, its real easy to fix don't pay the 100 dollar an hour rate the stealership wants and fix it your self. Or shared_pm me I have the black sticky seal needed to fix it. But yeah that is you problem.
