need b series cv axle for driver side a.s.a.p
Old Aug 14, 2010 | 02:25 PM
stangman289's Avatar
Default need b series cv axle for driver side a.s.a.p
when i drive my car it jerks to the left, and makes a noise, i was told it was rack and pinion, i replaced it steering is stiffer but the same problem occurs, i have a rip in the cv boot, i was now told the axle is snapped and has play inside causing it to jerk it also clicks just going straight from the driver side tire. could it also be a wheel bearing? if you have a axle for cheap let me know asap thanks guys
Stangman289/Tyler (352)556-8024 Call/Text anytime!!! [/COLOR][/COLOR]
Originally Posted by Ashy-Larry
^^^Yea, we all knew it would be a matter of time b4 the Honda crowd realized Hondas weren't cool and wanted to jump on the drift wagon.
Old Aug 14, 2010 | 10:07 PM
its for a b16 tranny
Old Aug 15, 2010 | 08:04 AM
flatrex's Avatar
crx hatch sedan
I have one. Is yours the female or male kind. Mines a male type.
Old Aug 15, 2010 | 02:52 PM
i dont think i know the difference?
Old Aug 15, 2010 | 03:23 PM
flatrex's Avatar
crx hatch sedan
Well its where it connects to the intermediate shaft it will either be a female end like something can be inserted into it or a male end like you would insert it into something.
Old Aug 15, 2010 | 05:57 PM
i need the whole axle
Old Aug 15, 2010 | 07:44 PM
flatrex's Avatar
crx hatch sedan
Yeah I know but you need to find out what kind it is, you would need to remove it to find out but I'm assuming its a female type. But if you find out its a male type I have an extra axle that I would sell for 30 bucks or 60 if you need it installed also
Old Aug 16, 2010 | 12:48 AM
do you know if a broken axle or bad axle would cause steering wheel to jerk violently? i replaced rack and pinion thinking that was the problem, tie rods are fine ball joints are fine and new rack and pinion. only 2 other things i can think of are wheel bearing and axle???
Old Aug 16, 2010 | 01:59 AM
flatrex's Avatar
crx hatch sedan
Wheel bearing would have been making a ton of noise before it would get to the point of causing major drivability problems but its hard to tell without seeing it in person
