CRX B20
i think around 4k you need a mount kit and the price of the swap plus you will need to replace the front spindles due to the weak suspension in the hf you need si spindles you also need a diffrent intake manifold if you run the stock b20 the manifold is taller on the crv i have injectors if you need them....josh
