car starts then shuts off
Old Aug 4, 2010 | 08:47 AM
92eghatchkid's Avatar
92eghatchkid
Default car starts then shuts off
ok soo i go to start my car its starts up fine then shuts off and the cel comes on. tried to get the code but will not give me one...after letting the car sit for a few hours cel goes away and car may start or do the same thing again..any ideas? i have a 92 civic hatch with a 92 b18a1
Old Aug 4, 2010 | 10:30 AM
Secondz's Avatar
Built Not Bought
Do you have gas? lol... Check if your fuel pump is working
Old Aug 4, 2010 | 11:54 AM
92eghatchkid
yeah i got gas and its kicking on.. only doesnt start every know and then
RHD!!
Old Aug 4, 2010 | 11:59 AM
amendoza's Avatar
main relay? when it does not start check to see if the main relay clicks?
Old Aug 4, 2010 | 04:42 PM
DC2_BoostKING's Avatar
CRAWFORD BUILT
^ if the main relay was bad it wouldn't start period.
1. check your timing
2. check dizzy cap/rotor
3. check fuel pressure
CRAWFORD BUILT
Gainesville Crew Member #1
DC Crew Member #23
Old Aug 4, 2010 | 05:04 PM
amendoza's Avatar
ive had a main relay that started fine in the mornings then after a bit of driving around go to start the car again have to tap on it for the car to start... they get hair line solder fractures in the relay.... after resoldering it never had an issue again..... im assuming when it gets warm it fuks the connection in the relay up.....
Old Aug 5, 2010 | 08:04 AM
JDM son!'s Avatar
Professional Hustler.
This kids a genius.
MONEY IS THE MOTIVE.
Old Aug 5, 2010 | 10:55 AM
Secondz's Avatar
Built Not Bought
Originally Posted by JDM son!
This kids a genius.
I know, You dont have to tell me
Old Aug 8, 2010 | 02:32 PM
e1000's Avatar
M.O.B.
Default same problem
i got a eg that doing the same thing .....did u ever figure out the problem
Old Aug 8, 2010 | 03:42 PM
SEEKERone's Avatar
Trialed for Treason
a bad main relay won't leave the check engine light on
considering this is a swapped car, you might want to check the ground wire at the thermostat...commonly left loose
this is the ground for the pcm and main relay...seen this a few times
Liar, you couldn't cut me deeper with a knife if you tried
