killswitch help
Old Aug 3, 2010 | 04:21 AM
Needfstwheelz's Avatar
^ HIGH...My Name Is
Default killswitch help
i had a killswitch on my starter..i had a friend who tried to change my starter but the one i bought didnt work so we left it un wired....how do I rewire it to crank the starter. If anyone knows how i can bring the car by for yu to look at.
97 Mitsubishi Eclipse GST
95 Honda Civic ex coupe
95 Eagle Talon ESI
92 Mitsubishi Eclipse GSX
90 Acura Integra LS
94 Honda Civic ex coupe
90 Honda Civic std hatch
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
92 Acura Integra Gs-R
Old Aug 3, 2010 | 06:47 AM
^ HIGH...My Name Is
really nobody knows how...its already hooked up but i need to have the starter wired into the equation...
95 Eagle Talon ESI
90 Acura Integra LS
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
Old Aug 3, 2010 | 07:17 AM
Gotin's Avatar
Sayien
Are you trying to install a kill switch w/ your new starter?
-B.J.F-
Old Aug 3, 2010 | 08:47 AM
KushedRacer's Avatar
put your switch between the power or ground wire so that you can disconnect (switch off) and connect (switch on) the circuit anytime you want.
Old Aug 3, 2010 | 09:31 AM
^ HIGH...My Name Is
its already been setup...but idk which of the wires on the starter is the power to kno where to splice in the switch....i kno ikno...we all gotta start somewhere..wiring is not my forte.
95 Eagle Talon ESI
90 Acura Integra LS
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
Old Aug 3, 2010 | 09:42 AM
BoostedRacerDad's Avatar
Pops
There are only two wires going to the starter. The larger wire is power directly from the battery and some people have a kill switch that disconnects this wire from battery. It is a huge switch and cant be missed it will be under the hood. The other way is to trace out the small solenoid wire which could be cut and a switch added in series. Trace it out and remove switch and remake original wires.
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
Old Aug 3, 2010 | 12:32 PM
MightyMaxGS-T's Avatar
first of all asking how to do the kill switch on a public forum probably isn't the best idea, second a kill switch on ur starter is useless as someone can just push start ur car or hard wire the starter. if you want a real kill switch shared_pm me.
PM me for any AC, audio, and wiring work on your vehicle. Including but not limited to car audio, alarms, gauge installs, custom clusters, full troubleshooting, big/dual fuel pump relay kits, battery relocation, factory radio iPod and amplifier integration, custom harnesses, and custom standalone ecu installs and much more! If you need it done, we can do it! Don't be afraid to inquire!
