crx swap help
Old Jul 22, 2002 | 08:02 AM
cykociv's Avatar
Up and running
The tranny cale that is on the car now will work with out any problems. The throttle cable will work also. I replaced mine with new ones. Cleaner install. I used Hasport motor mounts and they also sell a linkage that will work for that application. As for as the wiring, its going to depend on what type of motor you have in the CRX. If its an Si the wiring is simple. If its the 1.5 I suggest that you contact Racing Works. They can make you a harness that hooks right up.
" Nitrous is like a hot chick with an STD, you wanna hit it, but you know what the consequences might be "
