Need help: EF Hatch only starts by push starting
i just got a ef hatch and they said something with the wiring from the starter is messed up i hooked it up the right way it goes and it didnt work so i tried running a wire from the starter to the ignition and it still didnt do anything at all what can i do?? please help
take the starter out and have it tested
also is the car turning over at all or do you get absolutely nothing from turning the key?
if you can only race me in a straight line then whats the point
...91 SMF SCCA
...91 SMF SCCAhttp://www.flickr.com/photos/8341770@N07/5601083432/http://www.flickr.com/photos/8341770@N07/5601083432/ by http://www.flickr.com/people/8341770@N07/, on Flickr
– the late Tom Thrash SCCA Solo E Production
Take a voltmeter or test light and measure from the large wire on starter to ground. If it lights or you have 12volts cable from battery is good.
Turn key to ON position
and measure for 12 volts on the small wire. Do you have it? if yes starter is probably bad. If no move to ignition switch.
With small wire(solenoid) off of starter and ignition switch on take a 12gauge wire and jump from Pos+ on battery to where the small wire was on starter. if the starter is good car should start.
Does your car have a clutch safety switch...?
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
JoKie TuNinG
StricKlyMT
727-510-6301
ok i just found out that i think i have 2step i have a rshared_pm module and there is a cable that is ran to the distributer a ground and another cable that i havent figured out where it goes yet if anyone can come fix the problem for me ill pay
Clicking noise? did you try to jump start it? Is you battery good?
TR"Old Skool EF & DA Crews" Member #46
TR "Wagovan Club" Member #1
This too... LOL
well i checked the batter and it was a lil dead so i got it charged and now it doesnt do anything i turn over the switch and the lights just turn on and the lights get a lil dim but does nothing at all i would like it if someone that new how to do wiring could come fix it for me i have money and will pay whoever can do it
