Non OBD to OBD 1
yeah jeff there is no reason to do that its not worth the time or money pre obd is way better anyways
less chances of codes being thrown
DONT SLEEP's penis tastes soooooo good
i think thas what he wants to do but u could use a few different ecus i heard with that swap but i dont know B- SERIES once u get it u cant go back lol
its really not worth goin obd1 on a mini me swap? cause i was lookin to do it? is ther any othe way to make it faster?
im runnin 88 si block
98 ex head
Y8 headgasket
zex cam
right now
stock crx si ecu
vfac
98 ex head
Y8 headgasket
zex cam
right now
stock crx si ecu
vfac
Guest
Posts: n/a
It all depends on you.......the p28 will give it a little of what it is lacking in terms of fuel and timing, specially with the zex cam, but I don't think it will be THAT much. What is it to you? If you already have the p28 and you are good at wiring, why not do it? It definitely won't hurt the car, the only thing that it will do it help it out. However, if you have to spend $300 out of pocket to do the conversion then I don't see a reason to do it if you're happy with the way your car is running.
L.
L.
