B16a+itr pistons
Old Jul 14, 2002 | 10:13 PM
Gotin's Avatar
Sayien
Default B16a+itr pistons
can it be done, is it worth it, what will i have to change. itr pistons in a b16a block?
Old Jul 14, 2002 | 10:28 PM
99B16Si's Avatar
you will have to change nothin. might as well change your rings while your at it tho. as long as everything is stock 81mm bore there should be no problems. it will actually lower your compression about a half a point...to about 9.7:1...better for boost but not all motor
Old Jul 14, 2002 | 10:34 PM
quicksilver EK's Avatar
The one punch machine gun
ctr pistons in a b16 block possible but not worth it
97 ITR-Mugen Equiped
04 Honda 600RR
Old Jul 15, 2002 | 10:03 AM
Gotin's Avatar
Sayien
would the endyn pistons be more adaquite for a all motor setup with a big cam?
Old Jul 15, 2002 | 11:46 AM
2qk4u's Avatar
i wouldnt waste 500 on forged pistons u dont really need.
if ur not goin boost dont waste 500. the stock pistons will be fine unless u plan on sum ungodly all motor beast.
if u have 500 to waste i would get them.
if not go with oem and save about half ur money
