noob ?
on
noob ?
is all b series wrist pins the same?why im askin is becouse i have a ls bottom and a gsr crank and gsr rods with p30 pistons but when i put the wrist pins in they just slide in with no problem well thats the problem.so if anyone has any info on this it would be great thanks
engine building &best
on
the wrist pin will slide in and out of the piston no problem,its the rod that holds it when it is pressed on..all bseries are the same dseries are smaller H series are bigger then both
i love AUTOZONE
i love AUTOZONE
on
ok that answers my question thanks but when i put the rod on the piston it goes thru that also so now im wondering if i have bad gsr rods or bad p30 wrist pins what do you think
on
do you have aftermarket rods?if so then you need aftermarket pistons..if you can put the pin in the pistons and shake the piston and the pin rattles then you have dseries..if it fits in nice and"tight"and still goes thu your "stock"rods then someone messed up your rods
i love AUTOZONE
i love AUTOZONE
on
the rods are stock p72 so im not shure the p30s came with the wrist pins but yea they could be d i have ls rods and pistons but i need to depress them to see if they fit other wise the rods are messed up thanks alot bro
Is it possible you can MIC the wrist pins and the rod for us? Im sure with measurements we can can figure out whats going on. Either MIC it or even a dial indicator maybe..
1999 Honda Civic Si
1984 S10 355 small block drag truck
1971 Toyota Pickup Converted 4x4
TR em1 crew #43
1999 Honda Civic Si
TR em1 crew #43
on
just to help ya bseries will be 56.08-12mm by 21mm around
i love AUTOZONE
i love AUTOZONE
on
well i think the end resault is that im goin to seee if i can trade my clean fresh gsr crank for a ls crank then i can use my ls rods so if you guys know anybody that would be interested in that lmk thanks
