rod bearings and arp's
Old Jul 3, 2010 | 04:26 PM
sovlisky's Avatar
Default rod bearings and arp's
i have a b20 and am going to put arp rod bolts in it and was wandering if it routine to replace the rod bearings and its a low milage motor probly around 50k on it
Old Jul 3, 2010 | 05:04 PM
Brandon H.'s Avatar
How do the rod bearings look? If they look good and clearance is good I don't see any reason to change them.
1999 Honda Civic Si
1984 S10 355 small block drag truck
1971 Toyota Pickup Converted 4x4
TR em1 crew #43
Old Jul 3, 2010 | 05:09 PM
DC2_BoostKING's Avatar
CRAWFORD BUILT
i always replace them, whenever the rods are pulled from any motor. especially if this is something your going to beat on.
CRAWFORD BUILT
Gainesville Crew Member #1
DC Crew Member #23
Old Jul 3, 2010 | 05:26 PM
88_Hatchy's Avatar
I'm cooler than you
When you have the ARPs installed the rods should be resized also. Changing the rod bearings and checking clearances is highly recommended.
Honda-Tech > TampaRacing
TR "Old Skool EF" Member #666
Old Jul 3, 2010 | 05:50 PM
CRAWFORD BUILT
^ with the ARP's they most likely won't need resizing. but DO check clearances, with a mic and not plasti-gauge. if they need to be resized then you'll need over sized bearings too.
CRAWFORD BUILT
DC Crew Member #23
