another location for EF main relay???
other than next to the hood latch has anyone seen the main relay somewhere else on an ef mine is not there.
its a 91 canadian civic EF. car wont start and the relay is not where it usually is. and i cant fucking find it its really pissing me off
its above front the hood latch.. like up under the front part of the left dash..
A bitch to get to...
here is the web page..
http://www.diymyhonda.com/civic/hard...-relay-repair/
ya i found it on my own before i saw this, and yes it looks like a motha fucka to get at, thankfully that wasnt the problem.
thanks though. had a bad ground but i found it and fixed it now car turns over but wont start, but fuel and ignition are working fine i checked them.
^ still check the main relay...!!!
its easy to get out.. remove the one bottom panel to the dash that clips off..
then take out the 1 10mm bolt all the way to the left bottom of the dash... the you can pull the dash forward a tad at the bottom so you can reach the bolt with a socket...
check the relay for any solder breaks it happens allot!
I just bought a crx from an old guy.. car hasent ran in a year.. fixed the main relay at his house and drove it home..
