troubleshooting ?'s for my ef
all u need is some brake parts cleaner.
take it apart theres a little screen inside spray it off and then dry it off and put it back in.
but i seriously doubt thats the problem.
did u check for codes?
id say map sensor if i had to guess it miggt not give you the code for it but if u can find a friend with a good one id try to swap it over.
check the codes there has to be some if its running like this
my car just was doing the same shit, it would idle perfect but soon as u hit the gas u get nothing and then it dies. changed map sensor all good
but what the f*** does he mean when im hitting rev limiter it revs up 2 1800 but i accelerated it slowly it will rev up but if i just step on it quickly it will just die
TR "Old Skool EF" Member #190
