Skunk2 coilovers...its not straight?
Ive adjusted my coilovers on my hatch and I cant get them level. I use to just use measure the heights by finger spacing to make them level. Is there a tool that I can buy to make adjusting coilovers ,making them level. (Right to Left) easy and more accurate?
WTB:A clean 90-91 civic hatchback. Red or black or white in color. Good exterior. Looking to spend around $2,000.
I counted 632 threads on the right and its still not straight should i count all over again.
I had this problem with my civic ex, what it turned out to be was at the top of the coilover(where the car sits on) the spring wasnt properly housing correctly. This caused the car to sit kind of at a pivot, just make sure everything is making contact correctly, also, make sure that you set each one up evenly. Sometimes it takes a little while for everything to settle into place.
03' BMW 330XI
03' BMW 330XI
Originally posted by "TenaciousC"
there's not a lot of threads jackoff
