Throttlebody......
Old Jul 10, 2002 | 06:05 AM
civicracer901's Avatar
B16ACRX
Default Throttlebody......
Is it better to get a bigger Throttlebody like a 68mm then a 66mm? Is bigger always better in this case? Would the AEM cold air intake still hook up to the Throttlebody with the larger size?
WTB:A clean 90-91 civic hatchback. Red or black or white in color. Good exterior. Looking to spend around $2,000.
Old Jul 10, 2002 | 08:21 AM
99B16Si's Avatar
bigger is not always better. it depends how much air your engine can flow. if u get too big of a throttle body at a low rpm itll feel sluggish. and, im sure the aem will fit, and if it doesnt buy a bigger rubber connector
Old Jul 10, 2002 | 08:58 AM
B16ACRX
Do you know why mine is really sticky its almost stuck closed. What causes that i took off my ITM to sale and I was playing with the throttlecable and realized that it was stuck and so i took a hammer and hit the throttlecable to open it. Now its just really sticky when it closes. Should I just get a new one?
What should I do? Do it need to be replaced?
Old Jul 10, 2002 | 02:35 PM
quicksilver EK's Avatar
The one punch machine gun
If you get a new one i wouldnt go biger then 66mm if you plan on stayin all motor.As for yours dont know how it would have got stuck.Mabe cleaning it would have been better then hittin it with a hammer ?
97 ITR-Mugen Equiped
04 Honda 600RR
Old Jul 10, 2002 | 03:36 PM
B16ACRX
No man this thing was stuck you couldnt use your finger to pop it lose to open I had to you force. Its fine now and i do have to get a new throttle cable anyways since mine is cut. How do you clean your Throttlebody out. Just a rag? Is there a safe cleaner I could use so lquid doesnt drain down inside?
Old Jul 10, 2002 | 11:48 PM
marksaccord95's Avatar
TR Registered Member #5
too big of a throttle body and you will get over the efficiency rate needed. u can clean the TB with some brake parts cleaner.
http://www.floridaracing.org
Old Jul 11, 2002 | 12:36 PM
Bill's Avatar
Livin' in Seattle
It's normal to a point but I don't see how yours could have gotten that bad. Regardless, the TB doesn't need replacing. Just spray some carb cleaner onto a rag and wipe done the bore.
