white smoke out my exhuast
i have a gsr eg hatch.
when i was driving yestarday and i went over 5k and my civic began to smoke white out the exhuast .. it will only smoke when i am over 5k rshared_pm ... i got new oil today and when i went to check the oil there is none
what could this be??? i am hoping to god its not the piston rings
THE SMOKE IS JUST WHITE NO BLUEE
cracked sleeve would burn water just like the HG would... But wouldn't you also have water in the oil unless the crack is all the way at the top of the sleeve?
Figure out where your oil leak is (drain bolt can be a pita sometimes), how much water are you losing, if any; and do you have any power loss/odd noises above 5k? Does it only do it with VTEC engaged?
