Fuel pressure question!
Old Jun 24, 2010 | 04:14 PM
Secondz's Avatar
Built Not Bought
Red face Fuel pressure question!
ok so i have a b20 vtec on boost with dsm 450 injectors and it has a stock fuel pressure regulator right now and im wondering if i should get a aftermarket fuel pressure regulator or just use a stock one?
also what pressure should i be at?
Old Jun 24, 2010 | 04:17 PM
omgwtfbbq!'s Avatar
I race sailboats
I'd recommend and aftermarket one, and your fuel pressure is determined by how much fuel you need, which is determined by your AFR preference.
Bitches don't know about the twin turbo
BLACK FENDER PART OUT
Old Jun 24, 2010 | 04:33 PM
custom240sx's Avatar
DC Crew Member #1
If the motor is tuned already don't touch it.
Old Jun 24, 2010 | 04:52 PM
Bry's Avatar
Bry
Stock one should be fine. I use a stock one on my car.
Old Jun 24, 2010 | 06:05 PM
YARO's Avatar
Smith & Wesson Protected.
Stock
-Induction Performance ALPHA Tuned.
-ROQUE MACHINE SHOP For ALL your fabrication needs.
Old Jun 24, 2010 | 09:11 PM
Secondz's Avatar
Built Not Bought
Yea its already tuned on it... but the one i had the fuel line broke so i just put a stock one on and im wondering if it would make a difference
Old Jun 25, 2010 | 06:42 AM
FrodoGT's Avatar
Found the Vtec switch.
The regulator isnt going to be phased by the injectors. What will require an aftermarket one is a high pressure fuel pump, like a walbro 255 hp. The stock one wouldn't be able to keep the pressure down with something like that. If anything larger injectors will make it easier on the stock one.
Also, injectors are flow rated at 43.5psig, but honda generally regulates them to ~39.
TR Old Skool EF Crew #24
Old Jun 25, 2010 | 08:14 AM
DC Crew Member #1
When I slapped a walbro on my stock unit the pressure at the fuel filter was roughly 55lbs...up from the stock 42ish.
I am confused, are you saying you had it tuned with an aftermarket regulator and then you went to a stock one or did you have a stocker on there at all times?
Old Jun 25, 2010 | 02:41 PM
Secondz's Avatar
Built Not Bought
Had a aftermarket then went to stock...
I have a 255 fuel pump
Old Jun 25, 2010 | 07:08 PM
Alpha's Avatar
Your best bet would be to ask your tuner where he set your fuel pressure at when he tuned your car
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
