need help/info k24a4
Old Jun 23, 2010 | 08:17 AM
integra's Avatar
90% grind 10% sleep
Originally Posted by jdmlife
yea your right its alot of shit involved just checked it out and dont think ima do it but ima get it just to have it and see what happens. im sure i can trade it for dohc swap
like i said they arent worth no more then 500$ so good luck on trading it.
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
Originally Posted by THE_ONE
Old Jun 23, 2010 | 09:42 AM
vonrobins's Avatar
love hondas ftw
the motors only worth 350 thats what i sell them for . with rods and pistons and a head and valvetrain and cams , a2 pump its a badass motor most setups around here make 240-280 hp , but stock a4 like 160 i think ,if you get that motor you'll still need a tranny,flywheel+bolts,pressure plate+bolts ,mounts,axles,kpro,02-04 motor harness,charging harness,fuel setup, crv mount bracket, header , primary o2 sensor,slave cyliner and clutch line , shifter box (i got 9 of them holla if you need one ) , shifter cables , type s half shaft and throttle body and harness conversion
Old Jun 23, 2010 | 11:04 AM
jdmlife's Avatar
thank you sir you posted all the info i needed and i will keep intouch with you for sure
Old Jun 25, 2010 | 03:54 PM
na200whp's Avatar
Powered by BOOST
Ill give ya 100-150 for the trans depending on what it looks like. That puts you around 200 for the motor. good deal. The trans will not work for you swap.
K series on crack
Street Car on 25PSI V V V V V V
http://www.youtube.com/watch?v=_sn1WsbI0UQ
S D M
