Symptoms of broke engine mounts...
Old Jun 19, 2010 | 07:27 PM
Brandon H.'s Avatar
Default Symptoms of broke engine mounts...
Driving around in the Si lately, since it has a fairly hard gripping clutch, I notice a lot of movement in the engine bay under full throttle between shifts. Almost feels like the motor is twisting
Is this normal or is that signs of bad engine mounts?
1999 Honda Civic Si
1984 S10 355 small block drag truck
1971 Toyota Pickup Converted 4x4
TR em1 crew #43
Old Jun 19, 2010 | 08:19 PM
MightyMaxGS-T's Avatar
lol know ur mounts are bad when u let of the gas and ur stick moves....
PM me for any AC, audio, and wiring work on your vehicle. Including but not limited to car audio, alarms, gauge installs, custom clusters, full troubleshooting, big/dual fuel pump relay kits, battery relocation, factory radio iPod and amplifier integration, custom harnesses, and custom standalone ecu installs and much more! If you need it done, we can do it! Don't be afraid to inquire!
Old Jun 21, 2010 | 08:43 AM
vonrobins's Avatar
love hondas ftw
i got all the stock mounts except for driver side which is the one that you most likely will need but shared_pm me if you need the other ones .
Old Jun 22, 2010 | 09:03 PM
JAVIELITO's Avatar
Check Back Mount
Originally Posted by JAVIELITO
to the grammar police of TR ... I DON'T GIVE A FUCK WHAT YOU THINK ABOUT THE WAY I SPELL
im sure i spelled that right for you all to understand.
Old Jun 23, 2010 | 05:50 PM
240_Sergio's Avatar
stock as fuk
definatly sounds like your mounts
