What do I put behind my clutch pedal so I dont dent the firewall?
Registered Hater
on
Auto to manual swap, I know the manual Civic I had deffinately had a rubber piece where the clutch pedal you make contact so you arent banging the firewall. Well I did an auto to manual and theres nothing in between. I kick the shit outta my clutch lol that bitch will end up making a huge dent in the firewall so what should I use to dampen it?
engine building &best
on
why are you pushing the pedal in all the way to the floor and so hard for,i would look into that first you have a problem with the master cyl or something,i did a a2m on mine i dont have anything behind mine i cut away all that thick ass foam but i dont have to press it down all the way to the wall..
i love AUTOZONE
i love AUTOZONE
Registered Hater
on
Its supposed to go to the floor I just dont want to dent my firewall. The clutch pedal comes down and has that thick metal bracket with a point on it where it would contact the firewall. Right now with no fluid in the master its sitting against the firewall. Your telling me if it rests on the firewall without anyones foot on it that its not going to dent it when your banging gears? Yes I push my clutch pedal all the way down shifting, its not an aftermarket pressure plate or puck clutch where your not supposed to.
Fill the fluid up and bleed the system.
Adjust the clutch and see if still hits.
If it does, plate of steel bolted in, with some soft rubber (tires for a 1/8th scale RC truck?) to make it softer.
Honestly though, the only time you need to be mashing on the clutch that hard is in the event of a emergancy stop. Otherwise you're just gonna kill the transmission over time.
+1
ZMRacin...for the people since 1998.
typeZ zionmotoracin@gmail.com
> #zionmoto #s1built #battlegroup3<
drag honda / drift soarer / road race benz
Registered Hater
on
+1 on filling it.-Bob
Adjust the clutch and see if still hits..............................Honestly though, the only time you need to be mashing on the clutch that hard is in the event of a emergancy stop. Otherwise you're just gonna kill the transmission over time.
