help with CEL codes
Old Jun 15, 2010 | 04:06 PM
mighty_mouse12's Avatar
MUSTANG NAZI!
Default help with CEL codes
So my girlfriend has an all stock 98 hatch with the y7. i was driving around the other night and the heater hose broke ipulled over right away it didnt eeven get past 5/8. well i took off the dizzy to get to the heater hose and after i changed the hose and put the dizzy back on it started throwing some codes. i was just wondering if anybody could tell me what will fix these codes
p0107
p0122
p0302
p0304
p0300
p1399
OLD SCHOOL EF CREW MEMBER #100
Old Jun 16, 2010 | 07:09 AM
shane thrasher's Avatar
code p0107 is a map sensor code
code p0122 is a tps code
code p0302 is a cyl. number 2 misfire
code p0304 is a cyl. 4 misfire
code p0300 is a random cyl. misfire
code p1399 doesn't come up as a correct code.
To me it sounds like when you were changing shit, you unplugged stuff, and turned the key to the on position, hense what your doing is "showing the computer" that the sensors aren't there, by having them unplugged. I see you messed around with the distributor. check your wires. Make sure they are plugged in all the way, and in there correct firing order. once you have checked all of that, and made sure your sensors, are plugged in. Clear the codes. and test drive.
Old Jun 17, 2010 | 09:46 AM
89crxsir's Avatar
P1399- Manufactures control Ignition system OR Misfire
SEE NO EVO HEAR NO EVO!
If i put half a tank of Shell V power, and half a tank of Chevron with Techron. Will i get v-tec??
Old Jun 18, 2010 | 08:19 PM
One of many.....when the distr was removed, did you unplug the wires for 2 and 4?
That might clear four codes.-Bob
