? 92 to 95 SOHC Vtec Axles to CRX ?
I have a 88 si crx and I am buying a 94 SOHC vtec motor (full swap)!! I would like to know if I can use the axles??? By the way, Can I use the clutch that is in the Vtec tranny??? I will be gratefull for any help!!!
drive that fucker like you stole it
Your gonna have to switch to a crx tranny because the 94 is a hydro, im running a dx tranny on my z6 swap, im gonna see how well it works for n20 then maybe switch to a si tranny. You wont need any axles as long as you use your crx trans, i sure you dont wanna go through the trouble of converting your cable to a hydro.
