Will i have to switch hubs
i have a 90 crx hf im putting a jdmd15b with a 89 crx si tranny in it will i need to change the hubs heard that hf's are smaller if so i have a set of complete arms with disk caliper and bearings from my 89crx si will these work???
also whats the model numer for the 89 si cable tranny?
thanks
thanks
engine building &best
on
yes u need to swp them..just go to the junk yard any Dx crx/civic will work to..
i love AUTOZONE
i love AUTOZONE
Actually you dont. Only the outer hub is smaller, the inner hub will go into the si tranny just fine. Its when you want to upgrade to bigger brakes or go B series (which had no small hub model) that you need to swap them.
TR Old Skool EF Crew #24
on
It's cheaper to just replace the whole knuckel then rebuild a axle safely for this application tho.
i love AUTOZONE
i love AUTOZONE
if by arm you mean the steering knuckle, then yes you could but make sure youve got axles to match or your going to be sitting there with you thumb up your ass..lol
The actual suspension arms are the same, you just swap one knuckle for the other.
ok thanks im using and si tranny and im going to get si axles
If your using an Si Tranny, then you need axles & Hubs (knuckles)...
88-91 SI, LX, EX DX knuckles & Axles will work...
It's not about horse power, it's about spline count..
TR"Old Skool EF & DA Crews" Member #46
TR "Wagovan Club" Member #1
