pr4 ecu or p75
Old May 16, 2010 | 08:18 PM
juice0808's Avatar
Default pr4 ecu or p75
does the obd 1 p75 save more gas than the pr4 cuz if so im gona concert to p75 , im spending way to much on gas
Old May 16, 2010 | 09:58 PM
mtber's Avatar
If you are "wasting gas" on a stock ecu you may want to look into other possible issues other then the ecu.
You need to post exactly what you have i.e. year/make/model vehicle, engine setup etc.
If your check engine light is on, check the codes & also post what codes are being thrown.
Old May 17, 2010 | 04:51 AM
juice0808's Avatar
its for my 98 tegg and i got my car wired to be obd2a and odb 1 its just wen i plug my pr4 in instead of the obd2 p75 i use more gas i was wonderin if i got a p75 obd1 would my car be as fast and still have the fuel efficency
Old May 17, 2010 | 06:29 AM
mtber's Avatar
Is the car throwing any codes on the obd1 ecu ?
Old May 17, 2010 | 07:16 AM
juice0808's Avatar
no, no codes
Old May 17, 2010 | 08:49 AM
00-Civic-Si's Avatar
Use the stock ecu for the stock motor.
