should tps read anything closed
Old May 8, 2010 | 04:04 PM
rangcrx's Avatar
engine building &best
Default should tps read anything closed
Meaning what should be the scale on the tps sensor?
i love AUTOZONE
Old May 8, 2010 | 05:24 PM
1lowSi's Avatar
1LowSi is a white guy
last time i did one was for an h22 it was .5 v at idle
checking from the 5v wire (iirc the middle wire)
VOUCHES on TR: eda6, 1LowEG02, SUPERCHARGEDCIVIC, Seasicksean, HonkeyDong, Supercrx88, lzylst
VOUCHES on H-T(jdmh22eg2) :neophyte210, RhdRicheeee, russlavoilette,lzylst
Orlandoforums (ThatWhiteGuy) -- Anyone
I LIVE IN DAYTONA BEACH
Old May 8, 2010 | 07:43 PM
BoostedRacerDad's Avatar
Pops
The potentiometer type of TPS is a variable resistor, effectively supplying a gradually increasing supply of voltage to the computer as the throttle is gradually opened. Usually the voltage operating range is from about one-half a volt at idle, to five volts at wide-open throttle.
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
Old May 8, 2010 | 07:47 PM
1lowSi's Avatar
there is a thread on h-t or go to ur local honda deal they will print off specs for u
iirc
.5v idle
2.2v at 1/2
5v at WOT
Old May 12, 2010 | 02:39 PM
R91Si's Avatar
.5v closed...4.5 wide open
Old May 12, 2010 | 02:43 PM
custom240sx's Avatar
DC Crew Member #1
I always set for between .45-.5 at idle (no higher than .5) and 4.5+ on WOT (no less than 4.5)
