NEED VTEC Solenoid Gasket Help!!
Old May 9, 2010 | 09:28 AM
PoisonDart's Avatar
thanks guys i didn't know the o-ring could leak from the same area so ill replace that next, as far the rtv sealant, i was unaware that i had to all that...so should i use it or not?
Old May 9, 2010 | 10:11 AM
1lowSi's Avatar
1LowSi is a white guy
^^ well that is really up to u if u do go SPEARINGLY WITH IT light coat around the very edge and let dry for aloted time
VOUCHES on TR: eda6, 1LowEG02, SUPERCHARGEDCIVIC, Seasicksean, HonkeyDong, Supercrx88, lzylst
VOUCHES on H-T(jdmh22eg2) :neophyte210, RhdRicheeee, russlavoilette,lzylst
Orlandoforums (ThatWhiteGuy) -- Anyone
I LIVE IN DAYTONA BEACH
Old May 9, 2010 | 10:32 AM
PoisonDart's Avatar
ok i just screwed up big time guys!! the connector with the wires that has the green plastic piece that inserts into the solenoid got broken as i was tryin to remove the o-ring bolts from the top. damn!!! anyone got that piece lying around??? i really need it!! pics are below..... Attachment 131736
Old May 9, 2010 | 10:36 AM
1lowSi's Avatar
check ur shared_pm i replyed i can do a tad cheaper on $$ than what i said i have 1 more than i thought so lmk
Old May 9, 2010 | 11:26 AM
Vtec4theChildren's Avatar
No do not use rtv on the o-ring or vtec gasket. Only place to use RTV-Gray is a small dab on the corners of the oil pan and valve cover gasket.
Old May 9, 2010 | 11:28 AM
chi town brat's Avatar
! Ne shab'rud'ni !
i agree
Old May 10, 2010 | 11:08 AM
  #17 (permalink)
PoisonDart's Avatar
ok so i called brandon honda and they told me that the "o-ring" (THE PART THAT LOOKS LIKE A SNOWMAN LOCATED ABOVE V-TEC SOLENOID)is not replaceable on my year model only 01 and up. he advised me to make one (which i have no idea how) and i should go to a auto part store (like discount or autozone) and have them give me a gasket kit... please if there is anyone who has this o-ring part laying around or know how to make one professionally, please let me know ill pay you for it and maybe installation. PM ME, EMAIL JABOMBA22@AOL.COM OR CALL 813-531-0217...JAYE.
Old May 10, 2010 | 08:58 PM
  #18 (permalink)
I looked and I don't have the piece.
1.I would go to a u-pull-it junkyard and carefully remove the piece.....sometimes you have to buy something else to get a hard to find part.
2.If it is a replaceable part for 01 and up, I would order one anyway (unless it costs a fortune) and see how close it is to fitting.
3.Next choice would be to do a racetrack repair
and make a connector. I have epoxied/gooped/glued/ultra-greyed/etc. pieces back together in an emergency. Have even made plastic parts sometimes, but it is hard to describe how I make something. It depends on the location, the circumstances, what the part looks like and I need to actually see something before a solution kicks in.
What part of town are you in? -Bob
Originally Posted by PoisonDart
ok so you was right it was the o-ring i pulled it out and noticed it was cracked (ill post pic on page) but within doing so i broke that little green connector piece that goes to the solenoid by accident!! so not i cant connect it back...do you by change have that piece laying around or you know where i can get one???? please help! oh yeah i got this stuff called (gasket sealant & dressing" from discount, will that work or do i need a specific kind?
