vibration/grinding question??
Old Jun 16, 2002 | 08:19 PM
naha08's Avatar
Default vibration/grinding question??
I have a 2000 prelude, for the last day or so when the car is between 2800 and 3000 rpms its making a sound like metal dragging on the ground " but not everytime, or unless i rev it up fast in neutral". i took the cat off and checked the heat shield but still making the same noise. any help would be great thanks!!
Old Jun 17, 2002 | 07:03 AM
hybriDevul's Avatar
Hot Dang!
have u got someone else to push the throttle while you look under your car ??? i cant think of anything that would only hit the ground during 2800-3000??? you say its like a scraping noise and not a rattle correct ???
if you cant see anything from under the car try popping the hood and takin a look ..
Old Jun 17, 2002 | 11:07 AM
naha08's Avatar
I had my friend push the throttle and it was making the sound at the headers from under the car. I would push up on the headers and the sound would stop, so I removed then retightened the flang bolt that holds the header to the bottom of the car. the sound stopped for a day then returned.
Old Jun 17, 2002 | 02:39 PM
hybriDevul's Avatar
Hot Dang!
tighten them more and use Loctite (sp.) the bolts should stay tight.
Old Jun 17, 2002 | 04:41 PM
naha08's Avatar
Thank you I will try that. thanks again!
Old Jun 17, 2002 | 07:33 PM
naha08's Avatar
Thanks cali i will double check that again.
