i gotta question bout my GSR
Now with more c5!
on
i just refilled my air conditioning with the coolant and now cold water is dripping on my right foot. im pretty sure its water b/c it has no color or smell. what could be leaking? the guy at acura said something about a cloged evaporation thing but i couldnt figure out what he was talking bout. somebody help please. whats goin on?
its your ac run-off IT WILL STINK IN ABOUT A WEEK. tear up the carpet and put the tube back in the hole . the water you see coming from the bottom of cars with there ac on is the ac run-off. after driving 10 minutes if you see no water coming from under your car you ac run-off tube is not in the correct spot.
explain a little more its hard to tell exactly what or where its coming from.
Anthony
Anthony
Drunmann Tuning's Scoob: 2.55 liter-6spd swapped Bugeye, fully built w/280 cams and a rotated Precision-6266
DD: 2010 MazdaSpeed3: Fully bolted and tuned
Drift Missile: S13 DOHC swap, welded diff = slidetastic
Bicycle: Kawi 636R.
Bicycle: Kawi 636R.
its jus a black tube i think 1/2 inch ? turn on you a/c and track it down you will see a whole in the firewall, wrappe in ruber. put it back in.
i had the same problem with my mr-2 i super glued the fuker back in.
Anthnoy
Anthnoy
Bicycle: Kawi 636R.
Bicycle: Kawi 636R.
glad to hear you got it fixed !
Anthony
Anthony
Bicycle: Kawi 636R.
Bicycle: Kawi 636R.
