b18c1 hatch
my friend did the gsr swap, but wants to hit mid 13's......turbo vs. all motor vs. spray...what would it take to hit those times all motor?or should he just hook up a shot ....he has nothing done except int. and exh..how much do stock motors hold?nO2 and boost...let me know what you think!
Aaron
~GST~
Aaron
~GST~
Leslie Said It Best
Spray Is Gay
Boost Is Good, But Expensive To Do Right
All Motor = Best
Spend Half The Cash You Would On A Turbo Kit, Ivest Into All Motor Parts & Tunning, Easy Mid 13's
I went 13.9 with short ram intake and a header in my gsr hatch...
new times up soon...And They Will Be Significantly Lower And Im All Motor
Spray Is Gay
All Motor = Best
Guest
Posts: n/a
I believe I have 1100 invested in my turbo kit, TOTAL. Which includes 2 BOV's 2 MBC's Several yards of IC pipe, the IC, The manifold, downpipe and turbo.
What did I spend to get it working at first? $800. If I woulda known what I was doing when I first started puiting it together? 360+275+80 = $715 manifold/downpipe/turbo/piping+IC.
*shrug* Maybe I got lucky.
just spray is gay
and if i'm not mistaken tamparacing's last "car of the quarter" is spraying, right? he's running 10's, yes 10's. do you realize how fast this is? or is this gay?
come on leslie...you'd probably give mark head for a ride in his car...
Guest
Posts: n/a
Thanks.. have a nice day.
you're right, i shouldn't respond but it makes me wonder why some people say the things they do when it sounds like they've never successfully turned a wrench before.
sorry, won't say anything else.
to get back on topic, i'd suggest going all motor. if this is a daily driven vehicle then reliability has to be a serious consideration. and, with turbo, there will always be reliability issues even if the entire motor is built properly. ask anyone on this board and they'll tell you that their turbocharged car requires constant attention.
if this is the case, that in fact its a daily driver, then getting more aggressive cams, advancing the timing, even going with a better drivetrain is a better investment and a smarter overall move. no, the high horsepower numbers won't be there, but the engine should make good enough power to get into the mid-low 13's. afterall, any hatchback (thats not an si weighing in at 2300+lbs) with 180+hp to the wheels will be into the 13's with a good driver and good tires. and as many dyno tests have shown 180+hp to the wheels in an all motor b18c is well within reach.
