Problem w/p28 & GSR manifold
Old Apr 11, 2010 | 10:56 AM
Gotin's Avatar
Sayien
Default Problem w/p28 & GSR manifold
b18c1/p28 (stock gsr map)/crx
I have removed all components that have to do w/ the butterflies in the GSR manifold (except the butterflies themselves). I have plugged up any unused nipples on the manifold.
The car runs great in all gears. The only problem I am having is the car will bogg for a few seconds in first gear a little after vtec crossover then run perfect.
Is this typical when running the stock gsr manifold w/ a p28?
-B.J.F-
Old Apr 13, 2010 | 06:31 AM
FrodoGT's Avatar
Found the Vtec switch.
Well that IS why those butterflies are there.. They increase low end torque and help higher rshared_pm flow as well..you get one or the other, and when they dont work, you dont get both.
TR Old Skool EF Crew #24
Old Apr 13, 2010 | 06:58 AM
Gotin's Avatar
Sayien
Thank you for your input. I understand why they are there. I am using a p28 with a stock gsr map. I understand that a p28 does not run the butterflies. During the time that I am driving the car (prior to buying a single runner intake manifold) I was wondering if this is the reason for the car bogging during vtec activation in first gear only or not.
If this is not a situation that you have come across please don't respond with obvious statements. Thanks.
-B.J.F-
Old Apr 13, 2010 | 05:39 PM
FrodoGT's Avatar
It wasnt a "well duh moron". It was me saying that you WILL end up with a bog on the top end since the runners are locked in position for low end power, and the fuel maps have been tuned to work in conjunction with the butterflies. I understand that unless you set up an output with a relay you can not operate the IABs with a p28, I have an s300 in one myself.
Old Apr 13, 2010 | 05:41 PM
mtber's Avatar
Get a skunk2 style intake manifold & a new eprom chip for the engine with the manifold & rock out.
