Accord timing issues help
Old Apr 1, 2010 | 08:19 PM
is dat Vtac's Avatar
Default Accord timing issues help
OKAY i got a 94 accord and the timing belt ripped off while i was driving..now i redid the timing and changed the water pump everything checked good ..cams at TDC and so is the oil pump but now it turns over and runs but really rough idling mad shaky..this dint happen b4 so i readjusted the valves and changed the spark plugs and still rough idle..what could be the cause of this???i redid the timing 4 times still the shit....and it has brand new NGK plugs an plug wires..
so what do i do now? hoping its not a bent valve
Old Apr 1, 2010 | 08:36 PM
YARO's Avatar
Smith & Wesson Protected.
Compression check/Leakdown test. Might have bent valves
-Induction Performance ALPHA Tuned.
-ROQUE MACHINE SHOP For ALL your fabrication needs.
Old Apr 2, 2010 | 06:22 AM
yeah thanks i was thinking the samething
Old Apr 2, 2010 | 06:27 AM
DC2_BoostKING's Avatar
CRAWFORD BUILT
+1 for bent valves
CRAWFORD BUILT
Gainesville Crew Member #1
DC Crew Member #23
Old Apr 2, 2010 | 06:55 AM
this car is a nightmare just did a head gasket job 2 months ago...changed EGR valve still wasn't the problem sounds like a subi except 10x slower.. and now this
Old Apr 5, 2010 | 06:12 PM
I go with bent valves.
I agree with Yaro about the compression test.
Let us know what you found.-Bob
Old Apr 7, 2010 | 01:01 PM
alright since its a bent valve how much does a valve job usually cost since i dont have time to wrench ? any good shops you would recommended?
Old Apr 7, 2010 | 06:34 PM
CRAWFORD BUILT
if you bent the valves then you have piston damage and possibly combustion chamber damage as well. you'll have to pull the head off to find out what all is wrong with it.
CRAWFORD BUILT
DC Crew Member #23
Old Apr 9, 2010 | 11:16 AM
Take it to Clearwater Cylinder head, Pinellas County.
Or NAPA main store, Hillsbourough County.-Bob
