running rich
Old Jun 4, 2002 | 12:52 PM
bluelude's Avatar
Default running rich
im running alittle rich and i was woundering if theres anyway i could lean it out alittle without buying a programer
Old Jun 4, 2002 | 01:34 PM
ghuey's Avatar
member
How do you know it is running rich.Unless you are fouling plugs left and right a wide band o2 sensor would be the best way to know if you are really runnin rich.Then you could use an adjustible fuel pressure regulator to lean it out.....
~Guy
Old Jun 4, 2002 | 04:08 PM
Sleeping_92_SI's Avatar
I kill 32-bit ECUs
if your running a TAD rich thats good, i exspress a tad
Anthony
Drunmann Tuning's Scoob: 2.55 liter-6spd swapped Bugeye, fully built w/280 cams and a rotated Precision-6266
DD: 2010 MazdaSpeed3: Fully bolted and tuned
Drift Missile: S13 DOHC swap, welded diff = slidetastic
Bicycle: Kawi 636R.
