chirrrping noise!!!
Old Mar 13, 2010 | 05:29 PM
notlowenf81's Avatar
Default chirrrping noise!!!
just put in a tranny and new clutch kit in my car. but i have this chiping noise that only goes away when i push in the clutch. i have a 98 civic. any ideas please help.. thanks
Old Mar 13, 2010 | 05:41 PM
88_Hatchy's Avatar
I'm cooler than you
throw-out bearing
Honda-Tech > TampaRacing
TR "Old Skool EF" Member #666
Old Mar 14, 2010 | 10:53 PM
customkid72's Avatar
its the diff berring
seffner meet getting started so click here to get inhttps://www.tamparacing.com/forums/local-events/745189-seffne-meet-lets-get-something-started.html
*ad removed*contact admin@tamparacing.com to ADVERTISE on here....
Old Mar 15, 2010 | 01:56 AM
sean83's Avatar
when you hold the clutch in or just when shifting? i have an unsprung clutch and mine chirps when shifting. If it makes noises when you hold the clutch in probly throw out bearing. If it makes noises in neutral with the clutch not pressed probably input shaft bearing.
Old Mar 15, 2010 | 02:02 AM
sean83's Avatar
did you put oil in the tranny? use syncromesh
Old Mar 15, 2010 | 07:49 AM
integra's Avatar
90% grind 10% sleep
its a throw out bearing you didnt lube it well enough...My roommates ITR does it and annoys me so bad.....
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
Originally Posted by THE_ONE
Old Mar 15, 2010 | 06:55 PM
sean83's Avatar
your supposed to lube the throw out?
Old Mar 15, 2010 | 07:45 PM
DRMORTY's Avatar
Once Ruled The World .l..
Or,
Feed the little Japanesse kids in the hamster wheel...
LMAO
J/K
TR
"Old Skool EF & DA Crews" Member #46
TR "Wagovan Club" Member #1
Old Mar 17, 2010 | 10:48 AM
ProjectLife's Avatar
+1
Old Mar 17, 2010 | 11:43 AM
TheRichMan's Avatar
isn't actually rich...
Sounds like the input shaft bearing if it goes away when you push the clutch in.
