lowering question
ok it might be a Noby question but i always stay stock hight so i don't know much about coilovers and shit .... anyways i don't know how low can i take my ef hatch with a b16 swap in there before my axles break bc too low or there a loud ass noise in my driver side wheel wen i drive
to slam it would be pointless on the streets of Tampa, you'll end up doing more damage to your EF then good.
buy adjustable coilovers and that way you can change the height of your car. remember, your camber in the front is not adjustable so the lower you go the more negative camber you will have which means the more uneven wear you will have on your tires. also if you lower your car do not use your stock shocks, they'll just blow out and you'll have issues that aren't worth it. so if you are going to do coilovers then do the shocks with them. there are a lot of good combos out there that aren't that expensive. suspension is important even in daily driving so don't cheap out and remember you'll need an alignment when you lower the car |
I lower cars with modified springs as well as install aftermarket items,
but there are limitations........ Axles might not break, but the oil pan is subject to manhole covers that are too high.........and sometimes speed bumps...... Some people drop their cars for a meet and raise them back up when they leave.......-Bob |
cut dem springz boiiiiiiiiiiiiiiiii!!!!!!!!!!!!!! lolz
