What Is This Connector?
Old Mar 2, 2010 | 02:09 PM
Hybrid_Ej1's Avatar
5th ej1 one in the making
usally theres a small box that hooks up to it for the airbag on the passgener side of the dash.
EJ Crew Member #2
Old Mar 2, 2010 | 02:32 PM
97dxcoupe's Avatar
ok so pictures have been fixed.. and to make it clear this is located in between the passenger & driver seats , right below the cigarrete lighter, behind the cup holders (obviously they have been taken out), oh yeah and my SRS light is on
i tried looking for it, but couldnt find one..
Scan tool.. How many wires in the plug?? 2?
2 wires in the connector. yup
im with 89 crxsir...if im not mistaken that should be for diagnostics...not your obd port but for srs....if im not mistaken lol.
so, leave it at that?? or does it need to be hooked up to anything
I © my Honda
i need
96-98 rear bumper (black)
96-98 fenders & hood (black)
rear filler panels (under tailights)
glove compartment lid/cover ( dark grey)
driver side ac vent(upper dash one)
TR "F#UCK Thieves" crew Member #10
Old Mar 2, 2010 | 02:36 PM
Hybrid_Ej1's Avatar
someone might of took out the box
EJ Crew Member #2
Old Mar 2, 2010 | 02:43 PM
97dxcoupe's Avatar
does this mean that stupid light is going to stay on forever? lol it frustrates me
I © my Honda
i need
Old Mar 2, 2010 | 03:01 PM
Hybrid_Ej1's Avatar
im almost postive, you can buy a box off of someone but then you have to buy the some exact passgener side airbag to that box. or you can just take the bulb out of the gauge cluster and your good to go
EJ Crew Member #2
Old Mar 2, 2010 | 03:43 PM
flatrex's Avatar
crx hatch sedan
Whatever you do if you do get the box and decide to reconnect it be sure to take both battery terminals off the battery to ensure that there is no power left in the car, failure to do this could end up with deployed air bags.
And yes yellow plugs are for srs on all cars equipped with it.
  #17 (permalink)
97dxcoupe's Avatar
FOUND IT!! the female side of the connector was stuck behind the dash. the sad part is that even after i connected it the SRS light was still on.. so iguess im just going to have to take the bulb out
THANKS GUYS!!
I © my Honda
i need
Old Mar 2, 2010 | 03:48 PM
  #18 (permalink)
flatrex's Avatar
crx hatch sedan
And touch the battery terminals together(pos. and neg. wires)
Old Mar 2, 2010 | 04:58 PM
  #19 (permalink)
89crxsir's Avatar
is it 2 gray or green wires?? if it is, thats you MES connector (Memory Erase Signal) for the SRS module http://www.dubovsky.com/projects/srslight/ how to reset the SRS light.. Some car makers like any german maker, you can access the airbags or any other module in the car thru the OBDII port. If any one wanted to know
SEE NO EVO HEAR NO EVO!
If i put half a tank of Shell V power, and half a tank of Chevron with Techron. Will i get v-tec??
Old Mar 2, 2010 | 05:36 PM
  #20 (permalink)
97dxcoupe's Avatar
Yeah, there is 2 gray cables, i will try this tomorrow as its too dark now . THANKS!
I © my Honda
i need
