fuse question..
Old Feb 24, 2010 | 08:04 AM
hateshino's Avatar
Default fuse question..
Hey guys,
My front passenger turning light is not running at all when my lights are on, but when I turn on the turn signal, it blinks. My front driver side turning/running light is working properly, as in it is solid when my turn signal is off, but blinks when I have the turning signal on.
I think its a fuse issue? But I have looked on the fuse boxes under the dash and under the hood and such but all I see are the high/low beams and such. What other name might this fuse be under? or might this be a wiring issue?
Thanks in advance.
Old Feb 24, 2010 | 08:11 AM
DRMORTY's Avatar
Once Ruled The World .l..
Check the Bulbs
TR
"Old Skool EF & DA Crews" Member #46
TR "Wagovan Club" Member #1
Old Feb 24, 2010 | 08:24 AM
hateshino's Avatar
the turning and running lights are 2 different bulbs?
Old Feb 24, 2010 | 10:00 AM
DRMORTY's Avatar
First check the easiest thing.. Like the bulbs. Before digging through your cars wiring.
TR
Old Feb 24, 2010 | 10:39 AM
HonkeyDong's Avatar
Every dog has his day.
It's probably a dual filament bulb, and only one of the filaments burned out. Happens all the time, take the bulb out and they usually look burnt.
Mattbuilt
AEM | Mugen | Skunk2 | Hasport | Hondata | Koni |Ground Control |
Old Feb 24, 2010 | 11:42 AM
hateshino's Avatar
I just checked and you guys are right, its a dual filament bulb. thanks!
Old Feb 24, 2010 | 12:08 PM
DRMORTY's Avatar
No problem
TR
