Battery Light Flickering??
Really tighten the belt...I mean you can flex it a good quarter inch after it feels tight. Use a big pry bar and a friend to tighten it.
If it still comes on after that check the connection on back of gauge cluster...a wire might be loose. Does it come on at exact same RPM every time you hit that rshared_pm...as in can you slowly raise rpms to that rshared_pm and get light to flick on at same spot every time?
+1 on volt meter to see what really is happening.. If it stays 13.5 at 8k then do what custom 240sx said "If it still comes on after that check the connection on back of gauge cluster...a wire might be loose. "
If i put half a tank of Shell V power, and half a tank of Chevron with Techron. Will i get v-tec??
SEE NO EVO HEAR NO EVO!
I put the belt on and got it 2 tight, lol
it was squeeling so much it was driving me crazy!
they gave me the wrong belt! no wonder it was fucking squealing! but im not sure if its still doing it yet! im replacing the clutch with a stage 4 unsprung... lol but ill keep you updated it im still having the battery light problem
I had a unsprung in my crx, and that was hell in traffic
unsprung clutches suck for daily driving, i'd use them on the track only. plus it's probably an on/off clutch 6 or 4 puck style. nothing beats a disc for maximum grip. that's why the high dollar carbon/carbon clutches are all disc.
CRAWFORD BUILT
Gainesville Crew Member #1
DC Crew Member #23
