Need help with electrical issues.
Old Feb 13, 2010 | 09:05 PM
AznDood's Avatar
Default Need help with electrical issues.
I have a dc2 integra and the battery keeps getting drained somehow. I bought brand new starter, alternator, and battery + new terminals. Checked the fuses and they all work and i still dont know what the problem is. Im about to give up on this car but i dont want to! Please help me!
Old Feb 13, 2010 | 09:14 PM
omgwtfbbq!'s Avatar
I race sailboats
Do you have any sound system components? Its probably a key off drain caused by a loose wire somewhere in the car. Happened to me when the negative terminal of my amp was loose.
Bitches don't know about the twin turbo
BLACK FENDER PART OUT
Old Feb 13, 2010 | 09:56 PM
AznDood's Avatar
I have a small amp in the back but i took off the wire for it. Thought that was draining the battery but it wasnt it.
Old Feb 14, 2010 | 10:12 AM
89crxsir's Avatar
How long does it take for the battery to drain down?
SEE NO EVO HEAR NO EVO!
If i put half a tank of Shell V power, and half a tank of Chevron with Techron. Will i get v-tec??
Old Feb 14, 2010 | 11:38 AM
AznDood's Avatar
couple of days when i got the new battery from honda.
Old Feb 14, 2010 | 05:23 PM
DC2_BoostKING's Avatar
CRAWFORD BUILT
hook a volt meter to it while it's running, and see if the voltage is dropping. alternator may be fine but the harness could be killing it. also could just be a wire grounding out somewhere.
CRAWFORD BUILT
Gainesville Crew Member #1
DC Crew Member #23
Old Feb 17, 2010 | 03:07 PM
AznDood's Avatar
Sorry im noob to all this. Do i hook up my volt meter to the battery or the alternator when its running?
Old Feb 17, 2010 | 03:29 PM
CRAWFORD BUILT
battery
CRAWFORD BUILT
DC Crew Member #23
Old Feb 17, 2010 | 04:05 PM
AznDood's Avatar
Just tried starting the car and it wont start. I started it a few days ago! this car is driving me crazy!
Old Feb 17, 2010 | 04:15 PM
CRAWFORD BUILT
you have a draw somewhere. i had a similar issue in my integra, my CD player wasn't wired correctly and kept drawing power, even when off.
CRAWFORD BUILT
DC Crew Member #23
