starter location on crx 91
Old Feb 10, 2010 | 05:32 PM
Zenkijavier93's Avatar
Default starter location on crx 91
i was wondering if someone can tell me the location of the starter on a 1991 honda crx. thanks.
Old Feb 10, 2010 | 05:42 PM
thegoldenchild's Avatar
seriously? its goes on the transmission under the distributor. 2 14 mm bolts
Old Feb 10, 2010 | 05:58 PM
chi town brat's Avatar
! Ne shab'rud'ni !
found this pic:
http://i72.photobucket.com/albums/i1...dsextended.jpg
Old Feb 11, 2010 | 01:01 PM
i dont work on hondas sorry. but thanks for the help.
Old Feb 11, 2010 | 05:59 PM
! Ne shab'rud'ni !
don't be sorry. ignore those who think everyone knows everything
if you Google honda starter you can probably find a good instructional write up for what you need to do.
the bottom bolt towards the fire wall is the hard one to remove. usually takes an extension.
Old Feb 11, 2010 | 07:18 PM
DC2_BoostKING's Avatar
CRAWFORD BUILT
^ w/ a universal joint.
CRAWFORD BUILT
Gainesville Crew Member #1
DC Crew Member #23
Old Feb 12, 2010 | 04:26 AM
! Ne shab'rud'ni !
thanks. I thought i remembered needing that as well and having to borrow one.
Old Feb 12, 2010 | 02:34 PM
thanks alot. :]
Old Feb 15, 2010 | 05:13 PM
well it wasn't his starter. but thanks for the help. i think its the dizzy or the ignition. which one do u think it might be. when he turns key over it doesnt even click...
Old Feb 15, 2010 | 07:33 PM
CRAWFORD BUILT
dizzy/ignition/starter aren't receiving a power signal if nothing happens. check grounds, loose wires, fuses, main relay.
CRAWFORD BUILT
DC Crew Member #23
