GAPPING SPARK PLUGS
Old May 21, 2002 | 01:50 PM
SMOKEM's Avatar
Ok I bought a set of NGK SPARK PLUGS PART #(BKR6E) FOR A B16 which ive heard that these r lil bit hotter plug than BKR5E any ways i know that they come pre gapped for factory 1.1 or something the BKR6e r gapped closer then factory. Should i gap the BKR6E to the factory specification or should I leave it alone??????????????
Old May 21, 2002 | 02:13 PM
Bill's Avatar
Livin' in Seattle
Run stock gap.
Old May 21, 2002 | 04:00 PM
SMOKEM's Avatar
What is stock GAP on a B16??????
Old May 21, 2002 | 07:50 PM
99B16Si's Avatar
i think its somewhere in between .040 and .045
Old May 22, 2002 | 04:41 AM
CarbonfiberR's Avatar
ITR
Originally posted by "Someone"
I think but Im not too sure that the BKR6E is colder than the BKR5E. The higher you go in number the colder the plug. Someone back me up on this.
Old May 22, 2002 | 04:47 AM
ITR
http://www.ngksparkplugs.com/techinfo/spark_plugs/overviewp2.asp
Try this website
Old May 22, 2002 | 09:40 AM
Sleeping_92_SI's Avatar
I kill 32-bit ECUs
hes right the smaller the number the larger the nose is therefore hotter the plug.
return them.
i dont like running hot plugs for the fact of detnation !!!!!
fuc that ill stick to my acs i dont need no pre- ignition.
Anthony
Drunmann Tuning's Scoob: 2.55 liter-6spd swapped Bugeye, fully built w/280 cams and a rotated Precision-6266
DD: 2010 MazdaSpeed3: Fully bolted and tuned
Drift Missile: S13 DOHC swap, welded diff = slidetastic
Bicycle: Kawi 636R.
Old May 22, 2002 | 11:23 AM
I kill 32-bit ECUs
woops my bad i meant the kr5es run hotter.
not to return the ones you had i thoght you had the kr5es.
thanks for the correction
Anthony
Bicycle: Kawi 636R.
